boxmod
POLE-POSITION said:jason i watched alot of you videos and your clutchkick entries get alittle boring. the Mid-Ohio event it looked like people were braking because you were going in slower then them then clutchkicking. yes that means no braking but it ususally mean throttle lift on the straightaway before the first turn. you are a good driver you should be able to get rid of the clutchkicking bad habit. Going in too fast then adjusting with the ebrake entry angle and speed it more what i think judges would want to see. thats is why i was so impressed with Noah and Erick's entires. who had the highest entry speed by the way.
take a seat, class is in session.
ok well lemme say this. Mid-Ohio was the first time I did tandem, the first time I was on something not called an OVAL and the first time I was really trying to push the car. it was ALSO 6 months ago. Yes that event I did lift some, but I still was entering 2nd earliest from what I heard/saw (only nate brasz with mega ebrake entry was before). People might also be braking because I was kind of underpowered compared to the 400hp truck, the huge power turboed mustang, the 400hp motul 240.... just maybe the 230 i put down accels slower and makes them adjust to me. but notice how i enter pretty close behind them (when following in tandem) pretty close... meaning they must be lifting also.
now with more events under my belt I am getting more and more speed entry type course and have been less lift if any at all. now if you know how racing/drifting works, there is ALWAYS going to be a point in the course on entry that you can floor it to, initiate, and make it work. ebrake just makes it earlier because the rear wheels are NOT pushing you toward the inside of the turn while being on throttle does. this means you must give the car a feint to the outside and clutch kick violently to keep you car from tucking in early. trust me.
goto some competitions, every competition ive been to since mid-ohio the judges say basically- no lifting down the straight/entry, and you can use ebrake entry but its not preferred. clutch kick or feint is what we want to see.
im not getting into techinque showdown here, but really, you are wrong here on what judges want, and clutchkicking is NOT a bad habit, there is no other way my 230hp is gonna spin some 245s on some 17x9 wheels. unless I get some much better grip tires in the front... like 235/40 615s hahaha- now while I did poorly in west palm, I have numerous factors that just arent working well together right now to cause problems.
and just for fun,,,
ebrake - e-brake drifting is looked down upon during solo type drifting competition.
http://www.driftsession.com/technique.htm
*also note my previously mentioned shift-lock technique is just like they say about downshifting into a turn, not as an entry.
class is dismissed.
another fun activity would be to google "drifitng technique ebrake beginner"...
*note, we are discussing entry and not mid-drift technique.
ok back to your regularly scheudled thread
--West Palm of Our Lives-- *cheesy soap opera music plays*
