what type of ignition does the ls have?
well technically its coil on plug but not quite the same.
They have a coil per plug but they have a regular spark plug wire running to each one.
Vh45de
- Forged steel crankshaft.
- Forged steel connecting rods.
- 6 Bolt main bearing caps with studs.
- Full-length main bearing bearing.
- Lightweight, floating pistons with molybdenum coating.
- Sodium-filled exhaust valves.
- Cross-flow cooling system.
- Hydraulic lash adjusters.
- Single-row silent timing chain.
- Coil-on-plug ignition system.
- Roller rocker arms for reduced friction.
- Variable Valve Timing.
- Redline of 6900 rpm.
- Compression ratio of 10.2 to 1.
- Bore of 93 mm and stroke of 82.7 mm.
- Dimensions: 890 mm(L) x 740 mm(W) x 725 mm(H).
The VH series consists of 4.1 and 4.5 liter engines from the Nissan Motor Corporation. The design consists of a 90 degree V8 with an aluminum cylinder block that features a closed upper deck and a deep skirt. The cylinder heads are also aluminum with a DOHC 4-valve design and pentroof combustion chambers.
mike your engine is supercharged?
v12 is mad heavy and too slow. they have decent top end speed but nothing off the line. A viper v10 would be a good choice if you can find one under 20G. Im sorry but no 240 is worth putting a viper motor in. You pay ten times the amount for your motor as you do for the car. Its like black people putting 30" rims on a $500 car is just dosn't make sense but to each there own.
