Anyone wanna tandem on XBL, hit me up - gamertag is also my member name.
Love my wall-riding RB26-powered Rossta S15
BTW, my basic tune for all my drift cars are like this:
*Full caster
*2-3 deg negative camber in front
*0-1 deg negative camber rear
*3/4 stiffness everything all around
*100% lock on accel, 25% lock on decel
*35/65 front rear brake bias
*Always use midgrade tires, 30 psi
From there, I go to a wide open test track to adjust based on power level:
*A little toe in for high power, little toe out for less powerful cars
*Stiffen or soften rear to remove or add traction
*Lower or increase tire pressure to increase or lower grip
I use the ebrake a lot to slow the car down coming up to the apex and lightly power over into full power. The tricky part is never lifting, becaues when you lift - you spin. You gotta keep the rear wheels spinning or locked to hold the drift. To keep drifting on the longer sweepers, just keep rocking the steering wheel back and forth and it'll keep stepping the rear end out, only if your car is slippery and fast enough to spin the tires.
