Ok so yeah I have a vibration coming from the front of the car. It seems to be originating from the passenger side. It starts to get really bad when I hit about 50mph. And when I say really bad, i mean like if I sustained that speed, I think my dash would rattle off.
Things I've done since it started:
Replaced wheels/tires with brand new wheels and tires - 100% sure they are balanced correctly and the tire is good
Replaced strut/spring assembly with Jic FLT-A2's. Everything is tight - I have gone over every nut and bolt multiple times.
Replaced rotor with brand new z32 rotor. Brand new pads too.
Pressed out balljoint and replaced with brand new OEM balljoint.
Notable details:
If I hit a large enough bump on that corner, what seems like a loud metal on metal bang occurs. Its totally solid, not like an intercooler pipe hitting sheet metal.
The vibration is intermittent - although after going with larger wheels, low-pro tires, and stiff sus; it seems to occur more regularly (like 85% of the time).
I'm replacing my inner and outer tie rods on Saturday although I seriously doubt they have anything to do with it.
The hub looks to be somewhat new. The bearing is tight, the surface has barely any rust, and the lugs look pretty new. I'm not sure whether or not they are aftermarket or OEM but I am 100% they have seen less than 10k miles.
I really want to get my car on a lift but i don't know anybody locally who'll give me access to one and driving long distances is scary atm.
There is play somewhere though - i just can't figure out wtf is going on. Any advice or help would be greatly appreciated.
Notable details:
