hachi
Oct 23rd
ATTENTION:
ALL DRIVERS AND RIDE ALONGS MUST WEAR PANTS AND CLOSED SHOES!!!
ANY DRIVERS WITH SHORTS AND SANDALS WILL NOT BE ALLOWED TO DRIVE!!
Gates open: 6PM
Drifting starts: 7PM
Event ends: 11:30PM
Cost: $25 to Drift, $10 to Spectate, $5 to Ridealong Ladies ride free!
Tech requirements:
13. PANTS AND CLOSED SHOES ARE REQUIRED FOR DRIVERS AND RIDE ALONGS
Guidelines:
1. DO AS I SAY!!
Questions/comments/concerns, post it here.
If you would like an instructor to assist you in learning how to drift your vehicle, PM Captain Ben. He will only be accepting 3 people to instruct at this event.
__________________
ATTENTION:
Gates open: 6PM
Event ends: 11:30PM
Tech requirements:
Guidelines:
1. DO AS I SAY!!
__________________
