D. Davaine
have you checked to see if all of your injectors are getting a signal, you could do this two ways one remove the fuel rail leaving the injectors on the rail and have a friend or who ever try starting the car and look at your spray pattern if the dribble out with out any pressure your injector(s) could be clogged or if you dont get any thing then your not getting any signal or you could just get a noid light and check it that way. are you getting spark on all the plugs? and is the spark strong? check that and get back with us
