Ahhhhhh damn!! Wifey is more important though
maybe in your house hold!!!!
j.k jk
I was talking about the people that dont even drive bitching.
Thats exactly how I was thinking they would do. Thats how I would set up the track. ANYONE can drift a 3rd gear sweeper. You have to have fast initiation to a quick series of switchbacks. Something has to change in speed in order for the competitive nature of the event to be a challenge. Doing a comp out of the main sweeper would be boring:driving:. Everyone would do the same. There would be no challenge. Ill take moderate speeds with technique over high speed predictability any day.
I predict crashes on turn 1.
I think they're usually the ones doing it. :chair:
The first right hander is going to have a minimum speed of about 65 if you follow the curve. If your car can't do 0-60 in less than 5s, it probably ain't gonna drift that first turn unless you turn in very late to sharpen it up. Then the left-hander will have a minimum speed of about 30... so plenty of braking/scrubbing.
To put it in perspective, the turns through the chicane area are about the same curve as the turn around the lightpole at CFRC. And that initial right hander? About double the speed you used in the right-hander that Herri set up.
This is all theoretical, of course.... I could be proven completely wrong.
I bet it's going to end up more like this, with a later, tighter entry on the first turn:
My car looks liike a bag of dicks
so same car with an LS now? hahaha
and I don't know about 15mph lol, but it is slower than 'expected' for FD. I kinda like the layout as long as its not as slow as youre thinking...
My two cents first turn might be close to 60mph but second and thrid will be around 15-20MPH
when we were runing the whole track those two turns were very slow and FD cut the area in two u turns. I would be surprised if they will keep that lay out, they should the very least take out the k-rails that separate the main straight from the shiganes and use the extra space.
But what do I know I have never drifted or organized an event Like Joong man wing here has
so same car with an LS now? hahahaQUOTE]
even worse with zenki front no kit + ls. You suck sir lol
