hachi
next two skid pad event dates
The next two skid pads will be;
Sunday March 14th 1130am till 530pm
Friday night March 26th 630pm till 1130pm
Cost: $25 to Drift, $10 to Spectate, $5 to Ridealong
Tech requirements:
Guidelines:
1. DO AS I SAY!!
Tech requirements:
Guidelines:
1. DO AS I SAY!!
