sidwayssilvia
Dude Change The Harness Trust Me
dont do this the only reason this worked for his friend is because he probably had a bad connection from dirty prongs on the engine harness check for solid connections voltage resistance these sensors use voltage to send a signal to the ECU if there is a weak or dirty connection it will cause resistance in turn sending the wrong signal to the ECU causing engine performance problems.
