crayZwhiteboy
a compression test will tell you if you have a leaking or bent valve...no compression
the coil pack test will get rid of the knock confirming which cylinder has a spun bearing. or possibly bent rod. but more common and what your explaining its another sr with a spun bearing.
let me explain. pistons are in each cylinder. compression fuel and spark explode causing piston to be shot down with a metric shit ton of force. those pistons are connected to rods. those rods are connected to a crankshaft. that crank moves the flywheel clutch etc making your car go. basic engine mechanics.
a spun bearing is where the rod meets the crankshaft. there should be oil between the two. if there is not then its metal on metal with again, shit ton of force. that causes a spun bearing. as you drive the car you are just making the gap between rod and crank larger.
coil pack test... with no explosion the rod is pulled down by the crank and then pushed back up. no knock.
WITH explosion the rod is FORCED down turning the crank and still has downward momentum. when the crank tries to push the rod up you get knock. because of the downward inertia of the rod and the gap between rod and crank. the crank actually hits the rod and thats what you hear.
so unplug spark and you take away the downward force allowing the crank to move the rod up and down freely
