2.5 on the hot side and 3 on the cold side.
Basic front mount will work 24x12x3 plus endtanks
Buy a good intercooler, don't buy the ebay crap.
reasoning for this??? i run ebay and i had greddy before this one...i didnt see any difference....and i kno chris jackson runs ebay on his too......what is the big difference besides spending the extra coin??
Other then Greddy, who makes a decent intercooler??
exactly what i was going to say, although i was going to suggest between 3" and 4" FMIC core, to efficiently support the power he wants, he'd need, IMHO larger than a 3"....
With the cheaper intercoolers the air intake temps get close to 200 degrees after a dyno pull or a pass or lap at the track. We changed to a garrett or percission intercooler and the temps dropped down to around 110 degrees. This has been noticed on a few different cars that I've been with tuning and at the track data logging, from s2000's to supra's with a AEM or Haltech. In one high powered car it was also making the water temp run at like 210 degrees after a pass. Not many people on here run a MAP based engine management system on here to see what air inlet temps get to so nobody would know how well the intercooler is working, and the hotter the air the less power and possible detonation.
makes sense....but with my ebay i'm seeing water temps no higher than 160ish at full load.....
Your water temp is a little low, The car that water temp reached 210 degrees had almost a 1000hp with a huge turbo, once the intercooler was changed the water temp was around 185 degrees after a pass 9.1 at 160ish mph, so I don't think it would effect your water temp, but air temp is still high.
And to add to my last post the air intake temps have been from cars 300hp to over a 1000hp, stock turbos to gt47's.
