slick... what you mean SPTs suck? what is that?...
good tires is deffinately a good investment tho.
240SicknessX said:keeping equal grip front and rear is safe.....
240SicknessX said:Im going to be nice here and tell you if you blew out a set of rs-2's on the front of your rx-7 you are definitely doing something wrong. Think........ ur supposed to be burning the rear tires while drifting. Im sure your coil overs fixed the problem though.
i have 225 45 rs-2 on 9 wide front.
Tonymac said:Well I have advice from a different perspective - to me, rear grip is more important.
240SicknessX said:ralph, i used kuhmo spt's at charolotte and they did not have 1\2 the grip my rs-2's did. I was used to the grip my rs-2s had. 340 tread wear........... pifft, more like 900 treadwear.
JeepsteR118 said:i get you now...i havent drifted in a bit due to my car sucking at life, but as soon asi get back on the ground i am gonna see if i can still manage to ge the ziex's to hold the front down around a turn....another tire i want to try is the toyo t1r i heard they are decent grip and nice daily tires....
240SicknessX said:btw, I agree, super front grip and bald 195's is gay drift and dose not teach you anything.
Tonymac said:Bald tires in the front? That's like a death setup! Just good tires all around.
I personally don't think its ever a good thing to have amazing tires out front with poop-spec tires out back - beginner or not. To me, you don't learn drifting that way.
Wider tires in the rear allow for more control while sliding. I think the biggest reason is their ability to cope with heat but I could be wrong. I think tire compound is more important than size (within reason).
jtmroczk said:good stuff there, i think where you are tying to go is balance, a large bias in front traction over rear traction will cause the car to slide too easily and spin often.
with the same tires/sizes front and rear: assuming you never break traction with your front tires they will stay under static friction(most potential grip). While the rear tires are spinning they are under kinetic friction(this has less grip). Speaking strictly in terms of tires, at this point you have a front grip bias out of the exact same tire front and rear(there are other factors that can be involved). This is the basic idea why people run a staggered set up, in order to increase rear grip, while sliding, closer to that of your front grip. This allows better control over the car.
its all about balance while sliding, I run 205/50r15 Azenis 615 up front and inexpensive but non-shit tires in a 225/50r15 out back, and both are stretched because "spring loaded' side walls are the worst.
