Can Someone Help Me ????
joker305
Banned
Need Help I Will Pay
Hey guys i need help installing a clutch pedal and master cylinder and slave that is all i will pay if i have to just lmk soon thanks
What condition is the car in right now? Have you started taking it apart? Do you have all the parts?
Are you sure the engine needs a head gasket? I REALLY hope you didnt trade your Z32 for a S13 with a fucked motor?
evrytime i try to start it blows a fuse
hey guys im posting this for a freind evrytime he tries to start his s14 the fuse blows the guy that he bought it from told him it could be fried ignition could this be true
Check the voltage the battery is putting out. The battery may be giving off too many volts.
^ possibly...
You may also want to check the charging system, the alternator, the starter, and the starter system. You may have a loose connection, or a wire that has become grounded that isn't supposed to be. While checking that you might as well check all the engine/chassis grounds in the bay...
Need Help Sanding a Car
hey i need help sanding my s13 becouse im going to paint it soon what is the best size sand paper size to sand my s13 please let me know
Go to Barnes and Noble and buy: How to Paint Your Car On A Buget by Pat Ganahl. All of your questions will be answered in there
need help my brakes do not work
hey guys my s13 brakes do not work at all i pull on the brake and it feels like nothing there but my e brake still work what do yuo guys think its wrong
My headlights wont go down
i wanted to know what is the cause that my headlights dont go down they still work when i put them down manually and put the lights on the go up but not down after
Does the pedal travel all the way down? Or is it hard to press the pedal?
-Check your fluid level.
-Check system for air.
-Check for fluid leaks.
-Check your brake pads. Do they squeak excessively, or make a grinding noise? May need pads and rotors.
-Is the brake booster working properly? Is the vacuum line connected?
-May also want to check the Brake master cylinder.
-May also want to inspect calipers.
I'm sorry, but I work at tire kingdom and i cannot tell you how many people neglect their brake systems. Even when you recommend things for their OWN SAFETY. This basically outlines a whole brake systems check, but you might as well do it.
It may just be low fluid and/or pad replacement.
yea the brake goes all the way doen when i checked the brake fluis it had none i filled it up a little bit but still not full but its still soft
