is no more
:bump:
What's an LSD? >_>
I tried to Google it but I it just came up with Acid :x
Limited slip differential.
Think posi rear end for your mustang.
Ok tire pressure. ive seen alot of people never even think about it so
if your car is underpowered add pressure to the rear
if you car understeers too much loose pressure in the front
IMO a good way to start is 32psi all around then ajust from there
and remember the more tire presure u have the less sidewall flex which makes for a feel of a more ridgid chassis.
hope this helps
c^^ another thing to learn lol but something i havent seen on here is about stretchin tires and how that can eliminate some wall flex for better grip......
it actually lowers the height of the tire slightly. stretching the tire forces the sidewalls out and are under tension already and therefore less or maby even no flex on an extreme stretch
ill let you slide mine anytime....if i ever get it towed to the shop and finished.
oh and proper technique> then any modification. ive seen people with sick ass setups not understand shit about how to drive a car and what to do with it when it does get sideways or when it won't get sideways. Single cam w/ lsd and springs with shitty tires and i can still shit on plenty of people with awesome setups. I like helping people learn how to drift. Its not always about teaching them on a professional level. its about teaching them the first proper initiations and timing and throttle control and it clicks "holy shit i can do this" I love when people get it.
fwd- means no u cant drift!!
how come? is it because you lose entry speed?Never Manji before a turn.
