Sorry bro, can't hear you over how much jizz is in my ears.
fix'd
fix'd
So who has the whole rule book?
Don't think our tire sponsor would like that......and only my cage is BLU808 that's why im building a new car.
this...... i want to see the whole thing
i got it but its not complete jet
no major changes other then this tire size rule, little here and there
i think you have to have fire suppression system now but that's about it my cage would actually pass tech too
that says 2010 book... wouldnt ya wanna see 2011?
what cage do you have?
What the hell...Tires must have a minimum tread wear rating of 140 (UTQG).
17 inch tires must have and MSRP of no more than $500.00
18 inch tires must have an MSRP of no more than $750.00.
19 inch tires must have and MSRP of no more than $1000.00.
Entrants must declare their tire manufacturer as a part of the event entry form.
Found someone posting parts from the rulebook in this thread http://www.socal-drift.com/forum/showthread.php?t=4012
---------- Post added at 09:01 AM ---------- Previous post was at 08:11 AM ----------
What the hell...
8.3.1.1 Exterior body panels may be replaced or modified between and on either side of the vertical planes described in 8.3.1. Exterior body panels consist of any panel that could be considered an exterior finished panel of the original OEM vehicle that is visible from the outside of the car. Any metal above the line formed by connecting the lowest point of all the windows may not be removed, including the pillars and the windshield frame. The exterior roof panel is able to be removed and replaced with a composite panel.
8.3.1.2 The original OEM floorpan must remain fully intact between the vertical planes described in 8.3.1, with exception of the transmission tunnel and firewall rule as described in 8.3.3 and the fuel cell rule detailed in 8.5.1. Transmission shifter locations may be enlarged or relocated in the transmission tunnel when non original transmissions are used.
8.3.1.3 The interior unibody must remain fully intact and unmodified around the entire outside perimeter of the vehicle, between and inside the front and rear vertical planes described in 8.3.1, from the original floorpan at the lowest horizontal plane to the roof at the highest horizontal plane, with exception of allowances given in rule 8.3.1.2, 8.3.1.4, and 8.3.1.6.
8.3.1.4 Other interior unibody structures may be removed between and inside the vertical planes described in 8.3.1 that are not part of the original floorpan or outside perimeter or the unibody. These items can include the original rear window parcel shelf, interior tabs & structures for interior trim panels, various tabs or mounts for unused OEM steering columns and pedal boxes, OEM battery boxes and mounts, and unused OEM windshield wiper motor mounts and dividers not part of the original firewall structure. Any other items, mounts, or structures intended for removal from the unibody must receive prior approval in writing from the FD technical manager.
8.3.1.5 Rear suspension tower cross-members located at the top of the rear suspension towers may be removed from the unibody only if a suitable replacement structure of equivalent strength is installed after removal of the unibody section.
8.3.1.6 Any unibody panels or part thereof not listed for approved removal from the unibody structure in rule 8.3.1.1, 8.3.1.2, 8.3.1.4, or 8.3.1.5
8.3.2 Suspension Design
The basic OEM suspension design type may be freely modified. The original suspension mounting “pick-up points” must remain in the stock, unmodified location.
I wish this rule changed so i could build stronger mounts and raise my rear suspension towers...
