What da hell should I do next????"HELP"
JAPONESE
My car been acting up weird later.first , sometimes it doesn't start and ended up jump starting it from another car.so I thought it was the batery.bought one and now it wouldn't start at all.it could be the starter or alternator.What other trouble shooting can I do to find some other ways to solve this problem....relays or other stuff.PLS help any input will be appreciated.....
clean the battery terminals then put it back. my car did the same **** and it was that simple to fix it. i thought it was the alternator but my ols man made me do this and it fixed the problem. also make sure they are tight when you put them back.
Sounds weird but have someone crank while u GRAB and SHAKE the harness right behind the battery. about 1.5" thick wrap of wires.
Or Hit the starter with a long pipe while cranking beware of positive wire on the starter.
2nd day trying to find any ways to get it started.no luck.THXS for the tips.anybody else???let me know.
"PINOY TALAGA"
im going through something similar. Try jiggling the key in the ignition while trying to kick it over. If you hear a click, its a bad relay.
Try hitting the starter LIGHTLY With A hammer Or Something Similar To It.... I guess 240's Have This Starteing Problem Happens To All My Friends With 240's
maybe its a nissan thing :\ lol j/k yeah like they stated before try hitting the starter that usually works...if its your started tahts busted.
if u hear a click the relay is working its if you dont hear a click then th relay aint doing shyt
Finally got my car fixed today with my boy DANNY helped me out.It ended up the starter was bad and the piece on the back of the clutch pedal was broken.Now I can drive my s13 again.Thanks guys for all the help.
