parts list
Items in Trailer:
-8 luminous yellow Rays GramLight 57D wheels 18x9.5 +12
-2 luminous pink Rays GramLight 57D wheels 18x9.5 +12
-55 gallon drum of Sunoco 110 octane race fuel
-Race Ramps part #RR-TR-7 74” long, 7” tall, 14” wide
Motor/Front End:
-FAST 102mm throttle body
-Chevrolet OEM LS7 Alternator
-OEM Nissan JDM Kouki s14 headlights both driver and passenger side. Passenger side plastic headlight bracket is cracked and JB welded together.
-Garage Autohero custom stainless steel tig welded upper radiator hose crossover pipe
-Koyo N-Flow SR20DET Radiator
-Blue HPS silicone radiator hoses
-Derale 16” black fan part #16516
-Derale 12” black pusher fan part #16925
-Trust/Greddy blue oil cooler
-Garage Autohero custom 4” aluminum intake pipe
-K&N 4” air filter with yellow filter sock
-Clutch master cylinder
-Sparco silver hood pins
-Seibon Carbon TR hood 97-98 Kouki s14
-Aeromotive A1000 fuel pressure regulator (red/black) part #13101
-Russel AN fittings on fuel pressure regulator -10 AN O-ring reducer to -8 AN (blue), -8 AN reducer to -6 AN O-ring (blue), -10 AN O-ring plug (blue)
-1.5ft of Russell -8 AN Proflex braided hose with grey silicone heat sleeve with Russell straight -8 AN to hose fitting blue/red and Russell 45 degree -8 AN to hose fitting black. This fuel line was attached to the fuel pressure reg.
-Stack fuel pressure sensor and Earls 90 degree AN fitting 1/8” NPT male and 1/8” NPT female (blue)
-Stack oil pressure sensor 1/8” NPT
-Garage Autohero custom aluminum radiator swirl pot with Griffin radiator cap and 3 blue Earls 1/8” npt nipple fittings coming out of the side. One 1/2” silver nipple fitting coming out of the bottom.
Interior/Exterior:
-Motec M4 ECU (gold) Serial #7670
-Stack ST8100 dash display digital/analog with data acquisition capabilities installed in oem s13 gauge cluster
-OMP Pista drivers seat with custom painted back: green/gold metal flake
-Buddy Club seat rails on driver seat
-Nardi 350mm deep corn steering wheel black leather w/red stitching
-Canton Racing 3Qt Accusump oil accumulator w/ pressure gauge and manual ball valve
-NRG Gold Gen 2.0 quick release
-Belle 1 communications radio helmet harness and push to talk button
-Red fire extinguisher
-Firesense SPA multi-flow AFFF steel mechanical fire suppression system
-Anodized red drift button
-Two Optima Red Top batteries
-S13 windshield wipers painted black with silver metalflake
