thats if the motor is fresh..like factory clearances. most sr;s are not rebuilt, they are abused and worn in so why would you put water in? we are in SoFla. 10w30 is water.
when my motor crapped out, i did not have my magical rotella T. i had some 10w30. garbage.
if you really cared about your motor i would run something a bit thicker.
the royal purple turbo motor oil is 20w50. so fuck what you herd.
I LIVE BY MY Rotella T 15w40. best detergent package on the market. keeps my motor minty fresh.
or you can listen to dumbass people and run the 10 30. g/l with that shit. might as well run water.
drftnR14 said:
ask estie!!!!!!!!!! they lock up lifters and motors fail!!!!!!! he swore by rotela 20w50 and now 10w30 is what he uses theres proof! if u know about engine specs and tolerance that info alone will provide u with enough information onto what oil is needed to run the motor and lubricate everything proply!!
paul your a fucking retard. you dont know shit. i runs rotella T sucka.
get the fact straight.
also if you knew about motors you would know as time goes on tolerances get way loose. so you need thicker oil to fill the void. think before you talk ass.
Rotella T 15w40.
its a mans oil.
and the only proof you have there is that you dont know shit about shit. fag.
