screaming6
I'm looking to buy some extended studs and some spacers for my weak wheels, maybe like 20mm(not sure size yet tho)
anyways , if I get extended studs with spacers do I still need extended lugs? Or run regular lug nuts?
I'm assuming that if for whatever reason I remove the spacers the regular lug nuts won't work.
sp should I run extended lugs regardless or with spacers do I need regular lugs?
any opinions on studs? Nismo arp, circuit sport?
