mr.chaka
im working on making a custom fuse panel for my s14. i have it started already. i just need some help on what goes where. mostly everything is going to be run from the switch panel, which are 25A toggle switches. i have 6 relayed fuses and 10 constant fuses. what needs a relay? what can be run just on the toggle? and whats the AMP rating on every thing?
things im using:
Headlights
Tailights
Running lights
Turn signals
Wipers
ECU
Dome light
IGN
Amp
Gauges
Cluster
cig lighter
2 rad fans
windows
alarm
fuel pump
help would be awesome. idk if forgot anything,
things im using:
Headlights
Tailights
Running lights
Turn signals
Wipers
ECU
Dome light
IGN
Amp
Gauges
Cluster
cig lighter
2 rad fans
windows
alarm
fuel pump
