usually you have to jam it in there ..its normal for a ka :bigthumbu mine gives me problems but i jam it in and it works fine then again i have an s14 tranny in my s13 so i wouldn't know
check your fluid i change my gears like that all the time messing around and nothing ever happens i go from 2 to 4 and 4 to 2 down shifting and it still goes in good ..just check your fluid take the fill plug out stick a ziptie in it see how much u have it should be just bellow the were the hole ends
When you go to put it in revers put it in 4th first then revers or if it doesnt go in just push down on it with not to much force almost like a regular shift and slowly disengauge the clutch it should pop right in key word is SLOWLY if not you will just grind it
