this has been an ongoing problem (expensive one too). before I begin I did some research and have come up pretty much empty handed. For some reason, when the A/C is connected and turned on, it will work for about 5 minutes and then stop. It is later to be discovered that a fuse has blown. We put a bigger fuse and it just delays the time of the fuse blowing. Ive been told it was probably the compressor, but since I dont live in japan, i cant just go off and buy a new one. Does anyone know if the jdm sr20det compressors have interchangeable parts with usdm sr20's? (like can i use the compressor clutch from a sentra with an sr20?) Any helpful information will be greatly appreciated. Thanx in advance
p.s. im well aware of using a KA compressor and rigging it on. But im trying to stay with the SR one and making it work
