Emeru
So i thought id see what you guys may think this was.
89 s13
blacktop sr20det
t28 @ 14lbs
walboro fuel pump
fmic
full exhaust from turbo back
The car idles fine, doesnt bog or anything at idle. Although my afr at start up go from 14.5 and drop slowly all the way to 12.0. Still no bogging or anything.
When im at WOT through the gears the car stays at around 10.5-11.0 afr. Also when i come to a quick stop the car acts like it wants to shut off for a second then it picks right back up to idle. I checked all my vacume lines checked for exhaust leaks found nothing.
Mind you the car never did this, it would idle at 13.7 ish give or take, and WOT would be 11.5-12.0.
My next guess would be either the MAF or the O2 sensor. Wondering if anyone has had the same issues before i start replacing parts.
89 s13
blacktop sr20det
t28 @ 14lbs
walboro fuel pump
fmic
