Sketchy564
so i was driving the other night and was passing by a turn ive hit a few times that im comfortable with and decided to hit it real quick. I didnt realize untill it was too late, but the sprinklers were on earlyer and the whole area where you would turn in was wet, so i understeered before the turn and was heading straight tward the curb.
i figured "no big deal, just straighten the wheel a bit and slow down so i dont hit that shit" . well my brakes are shitty as fuck no matter how much i bleed them, and just the front right wheel locks up with my foot down any more than half way on the brakes, so in any emergency situation, i cant slow down for shit, the same reason i rear ended that old lady that stopped short in front of me (time for brake upgrade)
so back to the story, i ran up on the curb facing forward, the front right wheel taking the initial impact at about 25-30 mph
that tire popped, and i i noticed that the right wheel was pushed back a little bit, and the whole assemby would wobble back and forth. I looked around with a flash light and narrowed it down to seeing the ball joint on the inner tie rod being loose as fuck and wiggling around. I figured thats also why the wheel was pushed back
I got the tire changed, and luckily i had brand new tein inners and outers that i never got around to putting on. I changed those yesterday, and the knuckle assemby stopped wobling but everything was still cocked back a little
i noticed the tension rod bracket was pretty bent, so ill be replacing that next, and the bushings in the tension rods were popped, so ill replace those with adjustable ISIS ones
but i looked at the FLCA on the pivot point where it connects to the car, and it looks like its stiting crooked. Im not sure if thats from the FLCA being bent, or some other shit being bent, which is pulling the FLCA backwards. Im going to replace the FLCA with these since my ball joints are also fucked, and thats one good fucking deal, its like $80 for just the FLCAs by themselvs
http://fcpimport.com/products/nissan-240sx-suspension-control-arm-suspension-kit-240sx-sk1
but before i start spending money on replacing shit thats perfectly fine, what else could be causing everything to shift back an inch or two like that?
id definatley like to get an allignment asap now that i changed my tie rods, and im getting new tension rods, but i want to fix this issue first
