screaming6
hello
so under light braking i mean like from 10mph or less if i sorta slightly press the brake(i mean litterally tap it) i get a pop....its sooo consistent that i can "tap" the brake let go...tap again and again and again and each time as soon as i do it goes pop.. pop.. pop....almost definetly from the front of the car...
if i ride or slam the brake or from higher speeds i dont hear it..
if it helps i have spl tension rods, steering rack bushings, subframe spacers... and buzz specs(kyb)....and RUCAS.
im thinking could it be front sway bar bushings?? since i know they are sorta bad....? or would it not cause this noise???? THANKS FAM
