misfiring ka :(
if your getting spark through the wire and its miss firing and your absolutely sure its cylinder 1 your plugs are fouling out, your gap might be to big and its blowing out the spark, cheap plugs , to much carbon residue, even injector staying open to long and flooding the cylinder till its pushed out, does it backfire alot
yes not alot but more than usual. and has a lot more hiccups during the idle. ill swap a diff spark plug next time it misfires. and there good plugs, ngk r. thanks ppl guys helpin me out
i have had this problem 3 times in the last 6 months so im just gonna buy new injectors cause mine just keep dying
put them in a rail with fuel lines connected and the harness and fire them outside the motor if you see clouds they are good if it streams out replace it or no fire replace it
well does it happens all the time? and mine doesnt stall out or anything. what have u tried that didnt work?
it started every once and a while but then just went all the time. ive replaced everything and i mean everything to do with fuel and igntion. once another injector dies im going to get all new ones cause it sucks driving home on three cylinders. oh and its a different injector each time.
u my friend have a diff. problem than me. 3 cylinder rides are soooo annoying especially when sititng at a light shaking nonstop sounding like a fuckin subaru
