Hey guys looooong time since i posted around here.
so looong story short.
car got hit by motorcycle on driver side on the rim. then car hit a curb softly on same rim (driver side.)
problem, car feels like it has a gap in the steering but is only after it starts moving, parked is barely noticeable.
changed, traction rod/tension rod to polly bushings, checked hubs (nothing),changed inner outer tie rods, changed steering rack, checked steering column, checked steering wheel, checked swaybar, checked wheel studs, checked brakes......
only thing i can think of is either lower control arm bushings or balljoint. or front subframe loose? or hubs loosening up after getting heated as the car starts rolling...
i dont know. but the car wheels wobble and shake violently specially after a turn or something, when i brake hard the car follows the crevices on the road and the wheels steeer the car to different sides as if one wheel had a gap that doesnt affect the other so is not tie rod/steering rack related.....
any ideas? im pretty broke also... :s
