Well, I wasn't to sure where to post this, so mods can move it wherever. They don't seem to make anything for the Toyota guys but I still wanted to share it. I think it's pretty cool and admire the labor to develop it. I hope you guys like it. . .
Vid of it in action in Inose's D1 S15(for more vids go to the Ikeya Formula website link below)
[yt]CZZhOU8MWmA[/yt]
Note: The price for this is around $1,200-500(usd).
More info and sources:
Ikeya Formula website with more videos:
http://www.ikeya-f.co.jp/en/index.html
To buy:
http://www.neweraparts.com/Default....EYA&CategoryID=1&List=0&Level=1&ProductID=163
PS This shifter makes me want to build a 240 just to buy it lol. :bigthumbu
Convert your standard gearshift to a sequential gearshift with this Ikeya Formula shifter. A bolt on unit, replacing the original gear stick with this clever unit, allowing you to shift gears in the same pattern as a race car!
Driving a performance car hard many drivers might have experienced missed gears, or incorrect shifts particularly from 2nd to 3rd and from 4th to 5th. Changing gear incorrectly or missing a gear can lose you time on the circuit, and can also damage the car. This unit allows you to change gears in a sequential pattern, pushing the gearstick forward to downshift, and pulling the stick back to change up. Use of the clutch is still required, as the standard transmission is still being used.
Extensive development went into the inner structure. It is designed to provide positive yet light action. This means errors and missed gears are a thing of the past with positive and precise shifts every time.
The Ikeya Formula is a fully mechanical unit: it has several advantages over complex electronics or hydraulics:
It is simple to fit; there are no complex electronics or hydraulics to set up or adjust. Simply remove the original gear stick, and replace with the new unit.
It gives you feedback; The use of a mechanism allows you the driver to feel the gears engage, so you know that you can floor the throttle again.
There is no delay in shifting; Because it is mechanical, there are no annoying delays associated with electronic or hydraulic systems.
The Sequential shifter is fully tested and certified for safety in Japan. A safety lever is used for selection of reverse gear so you cannot select it by accident.
Get one today and make missed shifts and ground gears a thing of the past!
Select the optional electronic shift indicator for reassuring gear selection notification. Easy to install and it can be placed almost anywhere in the cabin. Place it close to your line of vision to know exactly what gear you have selected.
To buy:
