you need DOHC power steering hardline+high pressure line if you are gonna have power steering. You need the DOHC harness, ECU, have to splice the dash connector plug from SOHC to DOHC just match the colors, its a little brown/white plug that goes under the dash by the glove department you'll see it when you take out the ecu + harness. Motor mounts are the same, should replace them anyway if u havent changed them ever. need a DOHC throttle cable, if you are using a/c, gotta use DOHC a/c lines and compressor+bracket. as far as the cluster working, either pop in the tachometer from a DOHC cluster or just get a DOHC cluster.. it's easier / faster just to swap clusters but if u can't find one and can only find a dohc tach than u can just swap the whole tach piece. that's about it. you can use SOHC 5spd transmission on DOHC and clutches and flywheel bolts etc. and lower tranny harness can be used from the SOHC also. i'm pretty sure that's about it
