please any feedback would be very help full. I was just wondering if ther would be a market for ka's i was planning on rebuilding ka motors mostly twin cams but for my prototype im going to use a single cam because i have a sensless attatchment to is lol and drop it in my car and dyno it so i can have some facts as to the power that you wil get out of the rebuild. Basically wut im going to put in the motor will be stock parts unless disscussed otherwise with the client it will contain a complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (it will not get a new camshaft, timing kit or oil pump unless you would want it ). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30. and depending on wut you want the motor for you can shave it if you going na or just port polish and a thiker head gasket if you wanna go turbo.
i just wanted to know if its worth it for me to do it or not. Also as a side note for those of you that are wondering if i have expirience building motors ive been doing it for about 1 year ive built 4 porshe motors 2 buggy motors 2 vw scca racing golfs 2 scca racing mazda miatas 1 scca racing civic si and worked on various other cars. please any feedback would be very help full
