NissanTech240
just wonderinng about the ichiba 5-lug conversion..good product or not..please let me know
Fronts are, but you have to use the s14 spindle and there are spacers that you need for the strut bolts. The s14 bolts are larger diameter than the s13 strut bolts. Or if you can get the s14 strut bolts with it simply drill a slightly larger hole in your strut mounts and it'll work fine - I've done it on 2 cars so far with no problems.
can u just replace the hubs?, the camber change using the s14s.
and for the rear can i use z32? or j30s?
