Hotshot headers??
Hi, I was wondering how much an s14 hotshot header would cost, and where one can be purchased. Also, is hotshot the best when it comes to headers?
Thanks
I've seen them go for about $300 on eBay. BTW, if you're planning to go turbo then don't bother getting them and just use the money on suspension but that's just my opinion/advice.
Thanks drftns14, and suislide240sx, Are these headers the best for an NA KA? Do they make a substantial difference in performance?
jdmnismo300 said:
20hp gain with headers?
One could only wish!! 170whp would require intake,header, 2.5" exhaust, cams, underdrive pulleys, ITBs (they're more for throttle response and don't see hardly any gain on the KA), fuel management system, stand alone ecu, ground wires (they help), cam gears, and other crap. It's worth the $$$. Standard KA-Ts and SRs have around 180WHP.
i Have an Na-ka i have'nt dynoed my car..but with lsd,11lb flywheel,compettion clutch,cold air intake,Headers,full exhaust,msd ignition...im running pretty fast.my next mods are intake manifold,cams,underdrive pulley,fuel pump.and some type of stand alone system with bigger injectors..im sure i'll be near the 200 hundred range...and thats barely touching the internals.
suislide240sx said:
But that's not street legal nor is it drivable on the street.
yea i know but estimated 340hp on a SOHC!!!! 200whp can be made on a DOHC n/a no one has used every part and done everything to the motor, just minor bolts ons and then they give up. honestly 180whp on a DOHC n/a KA can be made easy this is just my opinion.
