Qualy was best 2 of 3 runs and the air temp had dropped atleast 10 degrees since practice. It was a tough guess for tire pressures to go qualify under.
Qualifying order
1Charlie Thompson
2Gary James
3Miles Flick (no tandem do to missing cage bar)
4Jason Jiovani (spin on fresh tires, took out a non clip cone = 0, 3rd run was sweet)
5Matt Dahm (Blue 350z)
6Adam Williams (green RB 240sx)
7Patrick Goodin (dead clutch slave)
8Dan Chilton, Jeremy Lowe, Red Silvia Coupe (crashed/broke motor) did not do qualifying.
Tandem at night, is AWESOME. And face shields are something important when someone like gary shoots a ton of dirt/rubber/smoke into your eyeballs.
Tandem:
Charlie gets bye-run
Adam gets bye-run due to Miles being ineligable for tandem.
Jason Jiovani vs Matt Dahm
Jason Leads gets adv.
Matt Leads spins, Jason moves on.
Gary James vs Patrick Goodin
Gary spins taps wall with back end.
Pat Spins (i think)
OMT
-Pats slave makes it really impossible to challenge Gary and Gary takes the win.
Top 4
Jason Jiovani vs Charlie Thompson
Jason follows, straightens near 3 corner. Charlie Adv.
Charlie straightens (I was told?) near same spot and we are going
OMT
-Charlie leads and spins final corner. Jason adv
-Jason leads and has good clean run. Jason wins
Gary James vs Adam Williams:
Gary Leads and Adam hits the first turn wall hard with the frotn corner. unable to continue Gary takes the win.
Battle for 3rd:
Charlie by default of no opponent
Battle for 1st:
Gary James vs Jason Jiovani
Gary leads, no major errors from either from what I could tell, don't know advantage.
Jason leads, no major errors from either again I get to go
OMT
Gary leads, a little more outside in first turn, hold its a little long and has to slow down to make 2nd turn, Jason stays on him- Final turn Gary shallow around cones and Jason takes it to the wall. (I think we were even? but no information)
Jason leads, nice outside line turn 1, Gary spins somewhere around there/transition to turn 2. Not knowing that I do and extremely awesome 3rrd turn only to spin 20 ft from exit.
Jason wins. I assume it was due to the fact I made it 90% of the course as opposed to 30% before my spin.
*Bonus
They had noodles sticking out about 2-3 feet from the wall in the outside zones. According to the judges Gary's slammed car apparently went UNDER them in turn one while qualifying and according to a spectator I was hitting them in the final turn during the Battle for 1st.
Battle Scars:
Also that wall was touched more than you know! I wrecked my exhaust on it, Gary white rx7 backed in in tandem, Adam seafoam green front ended, Dan in red 350 widebody front ended, Pat white 240 coupe backed in, Matt blue 350 smacked back end, Charlie stock KA black hatch slapped back corner, J-Lo before black FC blew motor he hit rear on wall too, and I guess the red sil coupe hit it too (i didnt see that one). its was a really bumpy/slipper/dirty course and pretty gnarly to drive on.
I tried to post some pics I found online and they are alltoo big for SFL gallery so I'll do it lata
