Dittoz7
Anyone knows someone that really knows there way around a KA. Problem just happens out of the blue. Sometimes it run right, sometimes it feels like it's gonna fall part.
A lot of grey and black smoke when it does start acting up.
Car can't keep idle, and suddenly just dies. (Unless you give it gas and then it sound like it running the most aggressive cam imaginable)
Hesitation when you give it gas, feels like instead of oil you're running playdoh.
Car sometime for a short period of time sounds like I have damn 2-step installed when in gear.
Shifter starts to swing crazy from side to side when in gear.
God awful smell of some kind of gas, not like gas station smell, like gas mixed with fart smell.
Gas mileage takes a dive to like 8-10mpg.
So far I've changed
Spark plugs
gas cap
fuel filter
coolant
(regular maintenance)
oil + filter
air filter
cleaned MAF + throttle body
KA has around 200-215k on it
Converted from auto to 5-speed (had the same problem when it was auto to)
Still running on the auto ecu.
A temporary solution I've seen is if you turn the car off for like 15-30 seconds and start it back up. 50% of the time it start running ok again.
Has anyone ever had a similar problem?
So far I've changed
Spark plugs
gas cap
fuel filter
coolant
oil + filter
air filter
