doug in nc
Pay attention in school for me. Please.
lol wat that sopost to mean
I think, he is worried about your uh-tro-shush spelling.
Just skimmed over this thread and found some interesting. Like injectors stuck open...and oil.....
Most likely its a fuel line hose with a hole on the top so its pissing gas hitting the hood and deflecting onto the exhaust side.
Have someone start the car while you have the hood open watching the engine.
Sounds like an easy fix. Even someone who doesn't know shit about cars can tell where gas isn't suppose to be
Good luck
HAHA
but for serious
im shocked that there is someone here that has a clue as to what they are talking about!
props to you doug!
can one of you people please explain how fuel would be on the outside of the header if the injector was stuck open?
when i read that i was like:laugh::laugh::laugh::laugh::laugh::laugh::chair::chair::chair::chair:
it has to be a leaking line somewhere, im thinking even if it was a leaking o ring or seal, why would it be on the header, the injectors are on the other side of the motor....
unless this kid thinks the intake manifold is the header.. which is entirely possible
Header or intake manifold?
my cuzin was looking when i was cranking. n fuel was comeing from the header because it not bolted on. dont ask me y fuel is going into the exhuast but that all i can see that i know of
lol put two and two together
so im assuming he knows what headers are.
if fuel is spraying onto headers because they arent bolted on all the way then fuel should be dumping out of your exhaust still in liquid form....
if fuel gets into the combustion chamber and doesnt explode it will keep getting full until it starts pouring out of the valves. in the mean time fuel doesnt compress easy like air so it will probably wash your piston rings out and mix in with the oil.
basically your engine is fubar'd
take it to a shop and ask them "wtf is wrong with my car"
I got this many:lol put two and two together
Ass-ume nothing. Logic would suggest that it CAN'T be the header based on the information provided. A loose bolt or two at the header ( (which... this is a 4 cylinder so why are we even using a plural use of the word header??) would likely cause an exhaust leak. Couple said exhaust leak with liquid fuel on it and we wouldn't be reading a thread about a fuel leak, we'd be looking at pictures of a pile of ashes.so im assuming he knows what headers are.
If fuel is spraying onto headers because they arent bolted on all the way then fuel should be dumping out of your exhaust still in liquid form....
If fuel gets into the combustion chamber and doesnt explode it will keep getting full until it starts pouring out of the valves. in the mean time fuel doesnt compress easy like air so it will probably wash your piston rings out and mix in with the oil.
