Dittoz7
Alright so my question is where the hell is this sensor located? I've never even heard of one even going bad before.
Backstory:
Recently the Kouki started running super rough, random sputtering, smelly black and sometimes white smoke from the exhaust. Check engine light has been on forever from what I thought was to be a bad trans. Finally got around to check the codes and the only one that popped up was P0450.
Checked online and it brings this link up.
http://repairpal.com/OBD-II-Code-P0450
Doesn't really sound like it's the problem I'm after but it's a problem none the less. So instead of dropping ~$185 on a new sensor I'm going to see if I can get one used. But since I've no idea where this (can't even find it on diagram) can't really pull or ask someone else to pull if i don't know where it is.
Also I believe my really problem is the FPR or as someone else suggested a bad injector/s. Going to pull my fuel rail and spark plugs tomorrow to check that out. What do you guys think it might be?
Backstory:
