LAST CHANGE TO QUALIFY THIS YEAR!!!!!!!!!!!!!!
END THE YEAR WITH A PRO LICENCE!!!!!!!
Qualifier date has been set with Josh and Dominick from OSW we will be hosting it on Dec. 13th, 2008 gates open at 9am and stay open till qualifying is done around 6pm. As usual for the Florida Pro Drifting Championship qualifyers the entry fee for the drivers is $100.00
This time there will be a Reserve only pre reg. meaning that you e-mail me your name, mechanics name and car that you will be qualifying with and I'll reserve a spot for you! Payment must be made at the gate on the day of the event.
Driver list is reserved to 50 MAX. If you cant make it please DO NOT reserve a spot!
Qualifying is done as solo runs only, so no cages are required, however everyone needs to have a minimum 5 lbs fire extingusher mounted inside their car. Long Pants are required!!!!!!!!!! no loose items inside the car or under the hood, Battery tied down properly, no leaks, all lug nuts in place, Helmet SNELL SA 00 or newer, etc... commmon sense stuff. if you want me to send you a tech sheet please e-mail me and I'll send you a copy.
make sure you get your name on the list quick since the reserve only spots will fill up quick!!!!
Send reserve a spot with the info to Harri@Ter-Tech.com
Sincerely:
Harri Tervola
Ter-Tech, Inc.
561-312-1871
Harri@Ter-Tech.com
Sincerely:
Harri Tervola
Ter-Tech, Inc.
561-312-1871
Harri@Ter-Tech.com
