[quote author=Josh link=topic=473.msg4846#msg4846 date=1266937201]
Judging will be myself and one other from the top left gravel island.
I am not sure how much practice time everyone is going to have, I am going to try and have at least 90 min from practice and 60ish for the comp but I cant say for sure. Drivers will each be assigned a number on their car so please be aware of numbers being called. I will try and get a bullhorn of sort so it will make everything easier to hear.
Based on points the top 4 drivers will drive against each other (no not tandem) for a new score. Then the first run and the second runs scores will be added and the highest two scores are 1st and 2nd. I know some sort of trophy is being handed out, I am not sure what it looks like nor do I have any info about it.
Pro-Drivers, Fellows, and a few others depending if they show up will have a 10 point handicap PER RUN. Sorry bros, it's for fun and charity, gives everyone a fighting chance.
If you have questions regarding the charity event please direct them towards will. If you have questions regarding the drifting aspect of the event, please ask me.
[/quote]
Scoring will be pretty simple, since this isnt an actually comp event everything will be very simple. There will be no speed gun but if you go to slow you will lose you drift which will result in a penalty. Spinning out, dropping both rear wheels, course out, and knocking over a clipping point will all result in a zero. Scoring will be on a 100 point scale, the entry is worth 20 at the first cone and 10 at the second, each clip is a possible 10, line/angle/smoke is 50. No additional points for sweet shit but I will give you a high-five.
This is not the standard way to score drifting but this is an amateur comp so it does not warrant it.
[/quote]
