viral5523
Since the car can move in reverse, all the teeth of the differential most likely are all fine. Now if the car was a bit rough when initially getting out of first gear, that could just be a sign of a tranny fluid leak. If theres low fluid, and the cars cold, the fluid would have to get picked up into the gears to then run smoothly. And of course, it also would run smoother when the tranny fluid heats up. If theres is a leak, then that would also explain the problem of the car not moving forward.
As for the symptoms of a bad vlsd, it wouldnt lock up the tires under high torque. It would slip and act like an open diff.
