WolfbaneDrifter
Hey, so I got a welded diff I'm gonna put in and I decided might as well get some solid Al Bushings to go with it....but I can't get the old bushings out!!! I don't have anything to cut them with or a torch... any suggestions on how to get the bushings out? Everything I find online just says "remove old bushings"...What I did try was using a pipe flange and a threaded rod with some washers to see if I could press them out (SPL parts says to do this to put the Al ones in) the washers just folded up inside the bushing...Should I just go buy a torch? lmk
thanks
thanks
