M miami-z Member Jan 23, 2008 #4 thanks for the help, i was told the opposite, fronts are different, rears are interchangeable
B BigCrash Member Jan 29, 2008 #5 The front shafts for the S14 are a bit longer than the S13 but they'll still fit. The rears aren't even close.
Tonymac P I Z Z A Driver Jan 30, 2008 #6 The FRONT lower strut mount bolts on S13's are smaller than s14's. S14's have a 14mm ID iirc while s13's are 12mm. In the rear, s14 coilover shafts are physically longer and it is generally accepted that they should not be interchanged although they can be.
