as long as its from a non turbo model with the right axles youll be fine. the twin turbo ones have the gear ratio that will slow you down
240sx W/ LSD: No mods needed if it is NON ABS
300ZX 90+ Non Turbo: Needs new output flanges (4.08)
300ZX 90+ Turbo: Needs new output flanges and gears are higher (3.69)
Infiniti J30 95+: No mods needed (3.96)
Infiniti J30 pre-95: Needs new output flanges
Infiniti M30: No mods needed
Infiniti Q45: No mods needed (3.69)
u need j30 axles otherwise, you will have to put one of the s13 6hole outputs on the driverside of the pumpkkin, and use one 300z axle and one 240 axle...worked for me...but like it has been said b4 need the right axles
Yea the non-turbo will fit just get j30 axles 5bolt, I used to have tht on mys14. but Id rather weld yours or j30.. z32 owners beat on there cars compared to j30s
