who here can do a manual swap ?
kwkouki
YOUS TROLLIN!
I am looking into a auto 95 zenki. The car is awsome, but automatic. I checked for shops around and the only one I see if XAT. $1600 seems outrageous and its in Tampa.
Who here can put this in for me? I want to help out though. I dont feel like its something I can do myself.
man it's incredilbe easy I did it to my S14 was also auto. you can use the pedal assembly from an S13 the clutch master cylinder , the clutch lines all from an S13 . As you unbolt everything from the 13 or 14 is the same way it goes back in. the only labor part is cutting the whole for the master cylinder but thats already marked where the hole needs to be.. trust I though I couldn't do it but seriously it's very very easy. Do you have the 5spd tranny with a clutch and a flywheel....?
I have a s13 that went underwater. I dont think I can use it now though > . < If I can that would be awsome.
check the tranny make sure it spins and can **** the other stuff dosent matter as much for being submerged as long as they arnt all rusted out
how would I check that if the car doesnt start?
well when you take the tranny off take the male end of the driveshaft and stick it in the female end of the tranny and spin the driveshaft... I don't remember. if it has to be in neutral or in gear but it should spin.. also if you use the submergerd parts try to clean them using the proper fluids throughly ie run a couple quarts of tranny fluid through the tranny to loosen up the salt deposits... Thats what I would do atleast bro..
Bring it to Ter-Tech. They've done a number of auto to manual swaps and can even sell you every part you need.
