Which tires?
I was searching the forum and i found a lot of ppl saying they liked the federal, bridgestone, bfg, nexen, and falkens.
So which ones should i get? Im running 205/60r15 right now.
Thanks,
-Pinoy
I've had a lot of good experience with the Falken Ziex series on the stock SE's. When I got my 17 FN's I went with Khumo Ecsta's and have nothing but good things to say about those too. But it depends what you're using them for - I'm assuming by the size it's on stock rims, so you'll want something good for daily driving - which I recommend the Falkens.
Bridgestone potenza are really good if u like doing some spirited driving here and there in the daily.
im rockin flaken ziex on the back right now and hancook rs2's in the front i love the rs2's they have pretty sick grip but low tread wear. ziex are great for the rear cause they are cheap and high tread ware
im running federal ss595 in the front w/ fuzion hri in the back. of course i daily and try to slide on the street once in a while. the federals have an amazing amount of grip but really low tire wear rating. the fuzions dont like to stick as much. they like to grip break loose and then grip but they have a higher tire wear rating. ride quality is great for 205/40 17. all i can say is find out what your needs are and go from there
Thanks for all the opinions.
I think im just going to try each set over time and see which tires i like the most.
First up is the Falken Ziex
I like the cheap ones lol. Might be hooking up with a set of michelin primacy's soon, 800 treadwear baby!!! I'll let you know what I think
