Which Router
Leo
do you have for your gaming system? I have a linksys WRT54G and it sucks! Imn in the market for a new one so I can atleast whoop some of ur asses in games :bigthumbu . Also provide ur pros and cons.
why dose it suck? Is it not allowing you to do something? Investigate network address translation (NAT) or individual access control lists.
it always needs rebooting and it works 20% of the time
Weird. My g/f has that same router (version 6 if I recall correctly) and we've been able to successfully connect a X360 and a Wii online. Have you tried upgrading the router to the latest firmware version? Are you opening up the right ports? More details plz.
rebooting? you mean it looses connection with the dhcp server (DSLAM?, dsl dist block). That could be a faulty uplink\WAN cable. Make sure you dont have the dhcp lease timer set short if you have the ability to change the duration of the IP lease.
Netgear is made of the souls of orphans.
Anguished orphans are not good at routing.
Also netgear is shitty as fuck. FOREVER.
Yeah, Linksys routers are good. If you're running an early version with early firmware, that might be why its acting up. I have a v5 w/ the latest firmware and it never needs rebooting. You sure its not your modem or the connection in general? I wouldn't hold too much faith in AT&T - they're out here on my job site fixing my T1 at least once every 4 months. >.<
