JTNismo
I sort of started this topic on another thread unrelated to this issue. It is not fair to the other person who started that thread so I decided to move this whole issue into this new thread. They mentioned a bunch of good shit about wheel spacers there and I became curious in researching what would be the best set of spacers for my Zenki. Please keep in mind this is for a daily driver, and temporarily, non-drifting vehicle with a stock KA. Right now, I am here only as an spectator but will turn to drifter once I can I afford it. Firstly, What is better: bolt-on spacers or the ones which studs have to be replaced for longer ones? Are bolt-on's really safe? How many LBS of pressure from torque wrench should be applied when installing bolt-on’s? What about them being hub centric? Sometimes spacers are not true hub centric and leave you with too much tire vibration aside from proper tire balancing. I want to avoid this vibrating inconvenience as much as I can. Any brand to go for in particular? What price do they usually go for?
My current wheel specs are:
Front - 235/40/18 7.5 wide and Rear - 275/35/18 9.5 wide
What would best spacer for this whip? I have the already very infamous in these forums Sportmax 962's. Maybe someone out there knows what the offsets are for these wheels. I don't really know and I can’t go check myself right now on the actual wheels because I just had tonsil surgery two days ago and I cant leave the house. Here some pics though. Maybe they help for now. This is where I am at. I already have 10 MM Eibach spacers non bolt-on's in the front only. Thanks in advanced for all your help on this matter!
MESSING AROUND WITH MICROSOFT PAINT, LOL!
THE REAL THING
SPOTMAX 962 SO WHAT!
I would really to get my car to look more less like the following two cars or somewhere in between, offset-wise:
To whoever the following car belongs to, I apologize for using ur whip as an example. It looks really good and, offset-wise, it is pretty close to where i would like to be at!
THE REAL THING
