Just picked up some tires to finally get mounted on my rims. Called Pep Boys and Tire Kingdom and both are about 23-30$ each for mounting and balancing. Anyone recommend a local shop in WPB that you trust with a new set of rims? Thanks!
The cameras at the tire kingdom in Jupiter aren't working right now so if you go in after 5 you just have to throw a tech some cash and they will do it
Went by walmart and they saw the rims and said they only do factory wheels so that was a no go... Ended up going by ter-tech and took good care of the new rims when mounting the tires. Thanks! @ Chris thanks tho!
