is no more
Between my server and my Windows Media Center home theater PC, I have at least two PCs on all the time at home. Have you ever wondered how much it's costing you to leave a computer on 24 hours a day, 7 days a week?
The first thing you need to know is how much power your computer draws. The best way is to measure the actual power consumption. You'll need a $30 device like the Kill-a-Watt or Seasonic PowerAngel to do this accurately. Once you get one, you'll inevitably go through a phase where you run around your home, measuring the power draw of everything you can plug into a wall socket. For example, I learned this weekend that our 42" plasma television draws between 90 watts (totally black screen) and 270 watts (totally white screen). Based on a little ad-hoc channel surfing with an eye on the Kill-a-Watt's LCD display, the average appears to be around 150 watts for a typical television show or movie.
But I digress. Once you've measured the power draw in watts (or guesstimated the power draw), you'll need to convert that to kilowatt-hours. Here's the kilowatt-hour calculation for my server, which draws ~160 watts:
160 watts * (8,760 hours per year) / 1000 = 1401.6 kilowatt-hours
The other thing you'll need to know is how much you're paying for power in your area. Power here in California is rather expensive and calculated using a byzantine rate structure. According to this recent Mercury News article, the household average for our area is 14.28 cents per kilowatt-hour.
1401.6 kilowatt-hours * 14.28 cents / 100 = $200.15
So leaving my server on is costing me $200 / year, or $16.68 per month. My home theater PC is a bit more frugal at 65 watts. Using the same formulas, that costs me $81 / year or $6.75 per month.
So, how can you reduce the power draw of the PCs you leave on 24/7?
* Configure the hard drives to sleep on inactivity. You can do this via Control Panel, Power, and it's particularly helpful if you have multiple drives in a machine. My server has four hard drives, and they're typically asleep at any given time. That saves a solid 4-5 watts per drive.
* Upgrade to a more efficient power supply. A certain percentage of the input power to your PC is lost as waste during the conversion from wall power to something the PC can use. At typical power loads (~90w), the average power supply efficiency is a disappointing 65%. But the good news is that there's been a lot of recent vendor activity around more efficient power supplies. The Fortron Zen fanless power supply, for example, offers an astonishing 83% efficiency at 90w load! If you upgraded your power supply, you could theoretically drop from 122w @ 65% efficiency to 105w @ 83% efficiency. That's only a savings of $20 per year in this 90w case, but the larger the power usage, the bigger the percentage savings.
* Don't use a high-end video card. I'm not sure this is widely understood now, but after the CPU, the video card is by far the biggest power consumer in a typical PC. It's not uncommon for the typical "mid-range" video card to suck down 20+ watts at idle -- and far more under actual use or gameplay! The worrying number, though, is the idle one. Pay close attention to the video card you use in an "always-on" machine.
* Configure the monitor to sleep on inactivity. This one's kind of a no-brainer, but worth mentioning. A CRT eats about 80 watts, and a LCD of equivalent size less than half that.
* Disconnect peripherals you don't use. Have a server with a CD-ROM you rarely use? Disconnect the power to it. A sound card you don't use? Pull it out. Redundant fans? Disconnect them. That's only a savings of a few watts, but it all adds up.
If you're building a new PC, it's also smart to avoid Intel's Pentium 4 series, as they use substantially more power than their AMD equivalents. Intel's Pentium-M, on the other hand, delivers the best bang for the watt on the market. Although it was originally designed for laptops, it can be retrofitted into desktops.
Source: http://www.codinghorror.com/blog/archives/000426.html
