sway bar clearance
Dr. Dooms
my front sway bar touches my oil pan because of the extra length of the rb
would any of the aftermarket sway bars give me more clearance?
or are they all pretty much the same shape as the stock one?
they sell adapters to move the sway bars down, but i thought that was only if you used a s13 xmeber, not the r32... mmm
try getting nismo mounts they make you motor sit a little higher?
try putting some washers where the sway bar bolts up to the rails of the car, maybe if you lower it it'll be in a spot where the oil pan is not touching it
hit the oilpan with a hammer
correct. the only other way to fix this is due ur research on mount kits. but then u have togo out and spend money!
so-hammer the oil pan in. no aftermarket swaybar will give u clearence. it will probly be worse due to the thicker size
