stroker kit
its a good buy if you want to seriously build the ka. especially for boost, because you can ask for low compression pistons and they will build it to your specs, just get your head ported and add the boost and its a recipe for fun
im pretty serious about building the ka up. i was trying to figure out what this would do if i buy the SC and just run it at 7-8 psi. or would i need to up the boost.
This is something to avoid unless you are already doing a ridiculous setup. The bang per buck ratio is probably low, and I'm not aware of anyone that's produced a dyno with this thing installed.
If you got money to burn then go ahead, as I'm sure every KA owner is dying to finally see this in action. However if you're on a budget, your money is better spent on forced induction goodies and a set of pistons.
It looks like you want a low end tq monster.
So stop thinking about 4cyls and get a lsx. I think it'll be cheaper for you in the long run too.
pm eddie at spool up racing, or main driver/owner of spool up has a ka strocker kit 2.6 ask him
